New member Username: Stjohnboy0000Post Number: 9 Registered: Dec-04 | i recently (about an hour ago) decided that i would build a slot-ported enlcosure for my s15l7. i have the both the recommended enclosure volume and pord dimensions for that volume from kicker. only thing is, im not sure exactly how the one piece of mdf that you see in the inside of the box should go (i mean how much space should be between that piece and the enclosure wall). |
Silver Member Username: Bdb_86Bemidji, MN Usa Post Number: 226 Registered: Dec-03 | what is the volume of the box how tall and how wide well the box be? |
Silver Member Username: RedskinLondonEngland Post Number: 122 Registered: Dec-03 | If you going to build the Kicker recommended box go here for detailed plans..... http://www.kicker.com/05/tech-support/manuals/manuals/04SL7%20Tech%20Brief.pdf |
