Square Ports
Username: Nickb920
I am building a ported box and it says to use two square ports. WHat is normally used for these ports.
well you would just cut out the ports were you would want to put them and then you would use a piece of wood you are using to make the box as a divider so you can have your chamber kinda seperate basically it would just be a wall and tune your box to however you may find fit for you and were would you be putting the ports.
Username: Byrumjr
Post Number: 60
They make square PCV. I used round PCV for my ports but the square should work too. Just have the right size and length.
