Installing a remote starter on a car with an existing Viper alarm.
Username: 1baraptor
TINLEY PARK, IL USA
I am helping a friend install a bulldog remote starter on his 2001 dakota. The question I have, is he has an existing Viper alarm (not sure what model) how should the install differ from normal with the existing alarm?
Username: Ps1k0
Post Number: 101
you have to look at the bulldog to see if it has a start activation wire (a wire that will start the alarm when it recieves a negative pulse).
if it dosen't have a wire that can do that, you can't use it.
if it does, you'll have to find the extra channel on the alarm (usually a white and blue wire). then install the remote start and connect the activation wire to the extra channel off the viper.
hope that helps.
I have a autopage car remote. Where can i find a wiring diagram for this remote. I am putting this into a 1998 Buick LeSabre Custom. I would appreciate any help I can get.
Thanks
