Help with system
Username: Njb920
Post Number: 11
Im thinking about getting 2 new subs and an amp and i was wondering if this combo work work out well and slam. I care mostly about spl, a Hifonics BX 1500d amp with 2 Audiobahn AWC12T 12"
Username: Taylor17
Kopperl, Texas
Post Number: 176
Sorry but I am feeling a little lazey, so could you post the spec's of the amp and sub's.
The reason I am asking is I think the subs are 6 ohm dvc, or I could be thinking of a nother audiobahn sub!
Username: Njb920
Post Number: 12
Audiobahn Sub
12" PERFORMER SUBWOOFER
Power Handling: 500 watts R.M.S.
Frequency Response: 25Hz-800Hz
Efficiency: 92.9 dB
EPDM Rubber Surround
Molded, Texture Injected Poly Cone
2" 4-Layer ASV Voice Coil
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Amp:
500 Watts X 1 @ 4 0HM
1000 Watts x 1 @ 2 Ohms
1500 watts x 1 @ 1 Ohms
Dimensions: 15.1 L x 10.4 W x 2.4 H
how much do you want to spend?
Username: Taylor17
Kopperl, Texas
Post Number: 180
I am gitting sleepy so if I missunderstand, sorry. I think they will match up! Wire each sub to a 2 ohm load and if I am reading the amp right, each sub should have 500 watt's.
On that amp the ratings you posted are rms right?
They will sound ok, but you could probubly get better for the price.
Username: Taylor17
Kopperl, Texas
Post Number: 181
Never mind!
I know that amp, it is a grate amp, that is it's rms rating's. Sorry, I told you I am gitting tired! lol
Just someone
I just have a stupid question I was thinking about running 4 type E alpines with two 1400 watt Boss amp(dont know the RMS) Would that be an Ok system or am i just living a lie
Just someone
