Help with amp and sub
Username: Bootykang
I have a 200 watt 2 channel amp hooked up in my car with some a crapping house speaker. I want to get rid of the house speaker and get an actual car subwoofer.but i dont know whats a good sub and how many watts the sub can have in order for it to work on my amp. Any suggestions
Username: Marley289
Post Number: 47
what is the amp model?
Username: Bootykang
VR3 2.0
Username: Marley289
Post Number: 48
did you buy it from walmart or am i missing something here?
Username: Bootykang
yea i bought it from walmart like a cheap b@stard
why do they suck or sumathing cuase i dont know nothing baout this stuff
Username: Marley289
Post Number: 49
lol well theyre not great by any means, if you are going to stick with that amp, i would recommend 2 subs, 12" that are 4 ohm single voice coils, and they are rated at 100 - 150 rms each. here is some that i recommend. (remember to buy 2 of them)
subs - http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13770
then once you get them, wire them like....
i know your amp is 2 channels but this will probably get you the best results
Username: Bootykang
alright thanks alot
