I NEED HELP
Username: Coxguerrero
Jersey Shore, PA United States
I have a Rockford CD player that i want to hook up in my car but don't want to cut any wires for the fact that even though i drive it it's still my parents car. Is there any kind of plug that will hook to my stock harness then into the harness of the CD player i want to put into the car??
And where do i get it at??
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 465
Its called a wiring harness adapter, and you can get them at walmart, or any car stereo shop. Make sure you purchase the right one for your car. They are model and year specific, so make sure you have the corect info for your car.
Is a smart harness the same thing. I just ordered one off of crutchfield.com so i hope it works
