15" x.x.x. in prelude
Username: Colinjay18
Houston, Tx Usa
i want to buy a 15" re x.x.x. and put in the trunk of my 1999 honda prelude. i want a sealed box. if anyone has any input on building a box, i'm really not sure on the diminsions yet. any help is appreciated.
Houston, Tx Usa
Post Number: 7
anyone?
Username: Araknid
BOCA , FL U.S.
Post Number: 204
My sis has a prelude and her 12" barely fits in the trunk.
Username: Zepp
Post Number: 44
i fit an se15 in my trunk, heres a link with pictures
http://www.carstereo.com/installs/photo_gallery_album.cfm?galleryid=366
the box is 2.2 cu.ft sealed, the x.x.x is recommended only 2
dimension-wise its a bit longer than the se, but take a look at my pics
Houston, Tx Usa
Post Number: 9
hey zepp, how does it sound firing up like that. it seems like that is the only way it will fit in my car too.
Username: Zepp
Post Number: 45
mine sounds excellent, it doesnt pound you the chest (mostly becuase of the sealed box), but it plays the lows like you wouldnt believe
make sure you get measurements for the driver so that you have ample clearance inside the box
