How do i hook this up :'(
Username: Kumanan
Post Number: 12
i got a clarion dpx1001.1 amp. below is a picture of the connection panel. I want to hook up 2 Dual 4 ohm L5's!.. can i hook them both up? my amp is 1000 rms at 2 Ohms bridged by the way. is my amp 1 ohm stable??Upload
Username: Carguy
Post Number: 1199
Yes you can hook them both up. Dual 4ohms will become 2ohms wired in parallel and your diagram says 1ohm minimum. You are safe.
