Power handeling on JL Components
Bronzed Auzzie
I am looking at buying a set of JL Audio XR653-CS 3-Way Components (top of JL range). I have acouple of questions...
1. Are they any good?
2. The are rated at 70w RMS. I believe they should be capable of handling much more but im not sure. im looking at 2 amplifiers to power them. one will give each 80w, the other 125w. Am I better off with more power - I dont want to blow them.
3. Will they be loud enough to keep up with 2 Image Dynamics ID max Subs, each recieving 800w RMS?
any one with some experience with them, it would be much appreciated if you could lend some advice. Cheers
Username: Jonathan_f
GA USA
Post Number: 3035
1) Yes. If you like the way they sound, then that's what matters. They're built very well and are well engineered components.
2)I've given the JL XRs (even the 2 ways) a 300/2 and they handled it with no problems. They're underrated.
3) Possibly, it depends on your tastes. The ID Maxes are loud, 2 especially. You'll likely have to turn the subs down a tad for the sound to be totally balanced, but that will apply for nearly any component set.
Username: Aaaavv
Post Number: 16
whats youre personal oppinion of the jl xr650 2 ways. i bought two sets of them. i also bought a 450/4 jl amp. i havent had it put in yet. how do u think that 450/4 will work. i know its 150 by 2 and 75 by2. my concern is that the front set is gonna drown out the second set
GA USA
Post Number: 3055
I like them, they're great for the price. The tweeter is a tad bright for my taste, but it's not as harsh as a lot of the metal domes out there. Mid is well balanced. With that amp and the 2 ways, the second set would def. be quieter, but remember doubling the power is approximately a 3db increase.
Username: Audiophile
OFallon, MO USA
Post Number: 115
hey jonathan, are you jonathan at Car audio Central, too?
GA USA
Post Number: 3057
Yep, just joined not too long ago. Can't come up with creative names :-)
OFallon, MO USA
Post Number: 116
Me too, I'm the same name there. :-)
