2 sony xplode 12" subs
Brian7779
Just got 2 sony xplode 12" subs and I was wondering if anyone recommends a amp to hook it up with. Says the subs push out around 800 watts at its peak. not sure if thats true. Can anyone throw out some recommendations?? Thanks.
Username: Vaio
Post Number: 19
IS it the sony xplod 1200WATTS AMP?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 150
there rated at 350 rms so find an amp that puts out around 700 watts
Username: Guitarplayer
how much money are you looking to spend?
A.C.
Hey brain, i had very similar subs (the only difference is that they were 1200W max) all i did which im sure every one in here is going to think is a bad idea is i purchased one of those crap sony x-plode amps 1200W max ones. i then placed the speakers in an enclosed box and it sounded so good that i was afriad that my car was going to fall apart. i didnt even need a capacitor however i would suggest getting one if your going to have any other speakers connected. but im telling you its a very good idea the amp puts out like 250rms per channel.
Username: Americanbass
Post Number: 40
lol a word of he wise just because a amp says 1200w doesn't mean it puts out that much. that value is how many watts the amp fails at and blows up. u want to look for the RMS value
