Quick ?
is there a tool you can use to tell the diff in wiring..as far as pos/neg..i want to rewire my 6X9's but want to make sure pos/neg wires are where they are supposed to be..
Username: Bdb_86
Bemidji, MN Usa
Post Number: 227
the speaker well either jump outword or inword they should jump out if there not then they are wired backwords
Username: Araknid
BOCA , FL U.S.
Post Number: 218
The wire is usally marked with some kind of mark on the positive side, like a small white line. opposed to the all black negative. Or the speaker should have a red dot near the + terminal and just remember what wire is hooked up to that.
Username: James1115
Ct
Post Number: 277
what kind of car is it ? and I will see if I can pull up your wiring diagram.
