Wireing two DVC JLW6's to 2ohms
Username: Xxkmfdmxx
Saint Petersburg, FL USA
Post Number: 258
How do I wire two W6's from 4 ohms to 2 ohms?
Username: Americanbass
well do u have them wired in series or paralell
Username: Xxkmfdmxx
Post Number: 259
Each are wired parallel
Post Number: 7
what kind of amp do u have. i can start by telling u if they are dual voice coils you run the first set of wires to the possitive and negative and then u run a seperate wire around the sub from the the first side to the other side connecting the positive to positive and negative to negative
http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2&image.x=17&image.y=14
Post Number: 9
does that help any
