Alpine CDA-9835
Jmw241
How do i put images or change the backround on my deck? Is this even possible? Also how cna i change the time from 24 hour time to 12 house time?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 91
push the volume knob then scroll through the menus using >>| and |<< till i see bg select or something then push volume knob again and that should work i dont think u can change the time on this one
Girlie Girl
Does anyone know if I bought the 9835 in the US, will it work in Europe??
Thanks
Username: Phx
Post Number: 23
yeah, unless electricity works in a different way over there :p
Username: Phx
Post Number: 24
the tuner will work for european radio too, if that's why you asked...
Girlie Girl
Thankx phx,
That's what I wanted to know. The guy at the store here in Holland is trying to get me to buy one from him, so I don't trust him. Obviously he's trying to scare me, and he almost did! He said that the tuner wouldn't work at all here. But the unit is 740 euro in Europe and 390 dollars in the US. That's way to much to ignore. Thanks again.
