Brahma set up
Username: Jbgoalie4
Utica, New york USA
Post Number: 22
I have a HIFONICS BX1800D which is 1800W at one ohm @ 14.4V. I will be purchasing a Brahma Mark II and would like some input on how I should set it up.
I would like to purchase a box so keep that in mind. I am looking for good sq and a lot of SPL. How should I set it up.
Type of Box?-slot ported, ported, or sealed
Size?
Wattage needed to push?
THANKS
Username: Hdubb
Farmington, Nm Usa
Post Number: 420
run ti at about 1200 to 1300 watts and get a slo vented box. if you get a box tuned around 40 to 45 if you listen to rap then it will be loud with that type of music. if you want to compete then get a box tuned in the low 30s. oops what size brahma
