Will my amp handle it????
Username: Shoaks
Hi guys
I have a JBL GT series 12" 1000w sub.
I'm considering buying the JBL 500w 4 channel amp that 75rms per channel, my ? is, will the amp be able to handle it????
Username: Carguy
Post Number: 1156
Why are you buying 4 channel amp? Are you going to use it for your sub? That amp bridged might be able to handle it but why not just buy a sub amp instead?
Username: Sparkey2027
Barnstaple, England England
Post Number: 58
you need either a 2 channel or mono block amp.
that sub is 250w r.m.s @4ohms. so look for an amp that gives out 250w r.m.s @ 4 ohms. try a alpine mrp 350. it gives out 200w @ 4 ohms, and its a good amp and a reasonable price.
