Whats the best head unit?
Username: Tips
Post Number: 41
whats the best hu money can buy currently? its not like i have the money... i was just wondering...
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 141
probably the CDA 7990 from alpine - F#1 status
think it retails for 4g glasswolf owns one so hed know
Username: Metalgearsolid
NJ
Post Number: 11
one heck of a head unit , isn't it? it feels good reading the specs off the monitor imagine how awesome it is to listen to it???? Glasswolf is a fortunate man!
ALPINE CDA-7990
IN-DASH CD TUNER AND AI-NET CONTROLLER
AlpineF#1Status
Optical digital output
Copper-plated chassis
MaxTune SQ tuner with hi-fi and normal modes
Bass Engine©
Detachable face-theft protection
BioLite display
Dual illumination buttons in green or blue
Black out display
Disc title memory
CD Text; CD Text display and CD Text scroll
Versatile-link ready
High-performance rotary encoder volume knob
Burr-Brown K-grade 96 kHz/24-bit sign magnitude digital-to-analog converter
24-bit Burr-Brown digital filter
High-precision DT and ST transport mechanism
STAR circuit PCB design
4V preout with high-performance DC-DC converter
3 preouts
External processor preset function recall
Multi CD shuttle control
Disc play and pause
Elapsed time display
Forward and backward
Random play
Music scan and repeat
Music sensor up and down
Title search menu and title search menu scroll
Direct disc selection
One; all Random play one or all
Bass center frequency control
Bass width adjustment
Subwoofer level control
Treble center frequency control
Anti-theft detachable front panel
Audio interrupt in
Bass Engine
Black coated CD mechanism and PC board
Black out display
Custom gold-plated RCA connectors
Custom titanium-insulated PCOCC RCA cables
Dimmer-on input
ISO-mount capability
Power antenna lead
Remote on lead
Direct access preset
Preset address indicator
12 FM/6 AM/6 DAP preset stations
8X oversampling (352.8 kHz)
45 degrees horizontal mounting angle
CD PLAYER
Frequency Response: 5 - 20 kHz (+/- 1 dB)
S/N Ratio: 120 dB
THD: 0.002%
Channel Separation: 110 dB @ 1 kHz
Dynamic Range: 100 dB @ 1 kHz
Sampling Rate: 44.1 kHz
AM TUNER
Tuning Range: 530-1; 1710 kHz
Usable Sensitivity (IEC Standard): 22.5 microV; 27 dBf
FM TUNER
S/N Ratio: 80 dB
50 dB Quieting Sensitivity: 13.5 dBf (1.3 microV @ 75 ohms)
Alternate Channel Selectivity: 80 dB
Capture Ratio: 2 dB
Mono Usable Sensitivity: 9.3 dBf (0.8 microV @ 75 ohms)
Stereo Separation: 50 dB
Tuning Range: 87.7 - 107.9 MHz
GENERAL-HEAD UNITS
Pre Output Voltage (Before Clipping): 9V
Bass Center Frequency Selection: 60 Hz; 70 Hz; 80 Hz; 90 Hz; 100 Hz; 130 Hz; 150 Hz and 200 Hz
Bass Control Range: +/- 12 dB @ 60 Hz
Subwoofer Level Control Range: 0 to -15 dB
Treble Center Frequency Selection: 10 kHz; 12.5 kHz; 15 kHz and 17.5 kHz
Treble Control Range: +/- 12 dB @ 10 kHz
Operating Temperature: 14 - 140 degrees F
Nose Piece Size: 1-13/16''H x 6-3/4''W x 15/16''D
Chassis Size: 2''H x 7''W x 6-1/8''D
Weight: 3 lbs. 5 oz.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7408
yeah I'd say the CDA-7990 (mine) or the ICA-901.
depends on what you want the unit for. the 901 handles DVD etc.. so it's more rounded for multimedia. the 7990 is a purist unit for audio only.
It retails for 3 grand. You can find tehm on-line for about $1700-1800. It's a great head unit though but really it's wasted money unless you have the rest of the system to match it's capabilities. Alpine's digital processors with optical connections are a great match. Beyond those I'd probably go ti balanced high voltage signal paths like Zapco's SymbiLink or PPI and Orion's older DIN cable system.
Then use good amps and pretty much the best SQ speakers you can find for the system.
Not really a head unit made for burping systems at SPL events. You could do that using a Mister Microphone and get just about teh same results.
Username: Glasswolf
Post Number: 7409
Not really a head unit made for burping systems at SPL events. You could do that using a Mister Microphone and get just about the same results.
Username: Tips
Post Number: 53
damn... i bet it sounds crazy sweet to the ears. i wish i could hear a setup with one of those.
Username: Glasswolf
Post Number: 7420
oops typo I meant to say the IVA-901.
it's alpine's new multi-purpose head unit. retails for about 2400 bucks.
