Glass or anyone else
i want to be herd
ok i talked to hunter yesterday but i cant find that thread so here is what i need to find out i got 2 hifonics 1800.1 mono amps and i want to run them each to there own sub but i want to get the sub with the hardest bass out of these 3 subs
2 12inch triple x's?
2 15inch triple x's?
2 18inch triple x's?
then i need help on witch box to use
ported?
sealed?
sloted?
then i need a battery for the back of my van witch would be best?
and last bet not least witch highs/mids and high/mid anps would be good to run with these subs and amps
ps i got my h/o alt already its 180 amps
thanks for your time and help
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7430
two 18"
slot-ported
use optima yellow top deep cycles for the audio system on a battery isolator
component amp and speakers will depend on budget and the vehicle, your tastes, etc.
lots of factors
