Custum fiberglass enclosures?
Username: Mbolin5
Has anybody here used one? I am thinking about making one, and i was wondering about the sound quality form the fiberglass enclosure.
How does it sound compared to a traditional wood box?
The answer is yes!!! It is possible to make a subwoofer box out of fiberglass!!!
Username: Mbolin5
That wasnt the question, at all..not even close
Username: Subfanatic
Walton, Ky Usa
Post Number: 99
haha....we know its possible anon...the question was does it sound good or better than a traeditional wood one...and matt...honestly..ive never heard one...i hear good things about them though and maybe it will be a good sound...if it sounds good tell me man..i might look into that...p out
Username: Jonathan_f
GA USA
Post Number: 3031
If it's done well, it can sound pretty much as good as wood. They just need some work. You have to remember with fiberglass that any panel you create absolutely HAS to be curved to have any strength to it. After that, sound deaden the inside of the enclosure and use polyfill. It helps. Last thing is to make it pretty thick so it's strong. You should be able to stand on a fiberglass enclosure with no problem at all.
