Cascade Performance Speaker Kit??
Username: Alexochoa
Tucson, Arizona USA
Post Number: 95
Has anyone used these before?
Are they any good?
"Place the Powerpads behind your speakers to wipe out cone breakup and distortion. Deflex Pads will help tighten up your midbass and improve your soundstage."
I'm going to install some CDT's (my first comp set!!) and i was wondering if i should pay the extra $35 for these kits.
Thanks in Advance
Username: Rick_ross
Post Number: 409
i had the trunk kit and it was good i had edead to and i liked the cascade better
Username: Alteraudiousa
Concord
Post Number: 1167
the powerpad is to break up standing waves, IIRC. I haven't put it in my doors but its on my list as I hope it will eliminate any chance of standing waves or dull midbas in my doors.
Username: Alexochoa
Tucson, Arizona USA
Post Number: 97
well, i guess it's a good buy. Thanks again for your input and help!
