Eclipse cd8454 preout question
Username: Runthunter
Post Number: 8
On the cd8454, I noticed that the preouts are 8v. My memphis amp goes up to 5v. Will this create a problem with setting the gain?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7388
set the amp sensitivity to minimum (5V) and either keep the head unit volume below about half way, or use a pre-amp or line driver to reduce the peak output of the head unit's pre-outs.
Post Number: 9
Thanks Glass, Would it be better to stay with a 5v head unit? It seems self defeating to get a 8v head unit and cut it down to 5v or would the sq still be better with the 8v?
