Does any one think this is a good match between subs and amps
lewisburg tn
ok ill start by telling you i have no idea on what im doing i just want a very hard hitting system for under $2000 so if this set up makes no sence then feel free to give me your in put ok im 23 and all i ever had was hand me down sounds but here is what im thinking of buying for my high top chevy van
ok here it is
#1 my head unit jvc kd-lh1000 cd receiver 50 x 4
$210
#2 lightning audio strike lsd10 1 farad digi cap
$95
#3 2 hifonics bx1000d brutus class-d 1 channel amp
1000-watts-x-1@1ohm
$245 each $490 for both
#4 2 rockford fos power hx2 rfr3112 12's dvc 2-ohms 150-1000 rms & 2000 peak
$350 each $700 total
now i have been told that 2ohm dvc can be wired to a 1ohm load so please let me know cause thats why i picked them amps. now my next thing is do you think i would need another bat and a bigger alt if so please let me know also do you think this is a nice setup if not please give your in put like i said i have not bought nothing so if you know some thing that would be better let me know last thing let me know if this will give me that hard bass that raddles windows[LOL] thanks in advanced for any info
Username: Sploosh56
Ohio
Post Number: 489
Receiver - Alpine CDA-9827
Subs - 2 12" Adire Brahmas
Sub Amp - Kicker KX1200.1
Put them subs in their own ported box tuned to 31hz. You'll definatly need a new alternator. This system should be plenty loud for you. If you want louder then you're crazy.
That cap is not big enough for those amps. You really should have 1 farad for every 1000w. But I would get a high output alternator before I bought a cap. A
Also, for 350 a sub, I would look at others. RE Audio to be exact.. Eclipse would also be better.
Username: Invain
Michigan United States
Post Number: 312
You really should look into Wahl's setup he suggested. With $2000 to spend, I would definitely get a better head unit than JVC, and I wouldn't really buy a Rockford sub period.
Rockford has great subs in the power series...I'd go with the 2 power hx2s...they should be plenty loud
