Dry Cell Battery
Username: Rob_brown
Post Number: 34
anyone who knows their stuff on car audio.. would you recommend a stinger 1000 dry cell battery, or a deep cycle marine battery, the optima yellow top? i am using it to power a hifoncs brutus 1500x1 or a jbl bp1200.1 for a RE triple X. Thanks for your help. Robbie Brown
Username: Rob_brown
Post Number: 35
Maybe even a jbl gto1200.1. Could you guys tell me what you prefer, or if you have a set up similar, what you are running? thanks for your help.
Username: Wojopro
Post Number: 127
yellow top
rockford gell cell
Username: Eclipse2005
Vicenza, Vicenza Italy
Post Number: 40
I would go with Optima Yellow top, i heard a battery called Vesna or something like dat and i heard it's really good.
