FORMULAS
Username: Eclipse2005
Vicenza, Vicenza Italy
Post Number: 35
what is the right and best formulas to calculate the internal volume of a ported box? Using Qts etc.. Thanks
Rob315
LxWxH divided by 1728...dont forget to compensate for the thickness of the wood....i just asked the same question in another post kinda. i gave them my measurements that i figured out and asked if i did it correct and figured out the internal volume. but thats the formula i have been given by jonathan(so its right).
Post Number: 36
That is correct but i was lookin for the one to calculate the internal volume for a specific sub...like Qts*Vas*D coefficient....or something like dat....coz im not sure what size it should be...For example, do i need 90liters or 75 or 110...you know what im sayin?
Rob315
ohhhh my bad. sorry its kinda late lol and ive been up for a while. but im going to have to pass on that one. i kinda know but i dont want to steer you in the wrong direction. sorry
Username: Redskin
LondonEngland
Post Number: 98
Download winisd from www.linearteam.org. this saves you the trouble of going through long complicated formulas everytime you change one aspect of box parameters. also if you go here http://members.aol.com/Dertaboy/Car_Audio_Tutorials/WinISD_Pro.html you can load your driver database with loads of parameters and save yourself some time.
