QUAD 2 OHM SUB
Username: Eclipse2005
Vicenza, Vicenza Italy
Post Number: 28
what is the best way to wire a quad 2 ohm sub?
Username: Sancho886
El Cajon, CA US
Post Number: 66
it depends on how many ohms your amp is stable at.
Post Number: 29
My amp works at 4 2 or 1 ohm.
Username: Its_bacon12
Hfl, Ny Usa
Post Number: 1215
wire it to a 2 ohm load...
heres what u do, wire 2 of the coils in series to a 4 ohm load, and the other 2 coils to series to a 4 ohm load, then after this is done, wire both 4 ohm loads in paralell to get a 2 ohm load
Username: Jmloughrey
Farmington, CT
Post Number: 795
god damn crazy quad voice coils...they ever come out with a sub with more then quad...like octagon voice coils...i'm gonna have to go into the store and just slap the owner of the store, "what are you thinking, how many hours do i look like i have to wire this beast, pay you to do it...i'd rather be attacked by rabbid wolves"
Post Number: 30
I'd like they build quad 1 ohm sub....so it would be great!!!
Username: Solacedagony
New Jersey US
Post Number: 170
They do build quad 1 ohm subs.
Post Number: 31
What is it?
New Jersey US
Post Number: 172
You can get quad voice coils from a few different companies. Since I ordered an RE sub, I know you can get them to build you a quad 1 or 2 sub. I'd imagine they'd build quad 4 ohm as well. Dual 1, 2, or 4. The triple X's come standard dual 2 though.
Hfl, Ny Usa
Post Number: 1216
my shocker is dual 1 ohm...heh
Post Number: 34
Cool, but what about a good quad 1 ohm? But dont worry guys, i'll find it out on internet. Thanks :-)
New Jersey US
Post Number: 178
Anything from RE is good. And other companies, I'm sure you could call them and ask them to custom build you a sub for a quad 1 ohm.
