Any way is this possible....
Username: Perrydog
Flint, Michigan USA
Post Number: 34
is there anyway that u can hook up to amps together and add their amps??????
Username: Carguy
Post Number: 1077
Yes it's possible. However, till depend on the manufacturer. Some make amps so that you can combine 2 amps together to form a stronger amp. Audiobahn makes one. I've seen their wiring diagram. They used 2 amps and combined the output stage in series.
