Amp cuts off when bridged
Username: Jdojao
I have 12 1200 watt solobaric with 400 2 channel autotek amp. I also have mtx amp that is running my front and rear speakers. I'm using 4 gauge wire. Every time I bridge the autotek amp. it cuts out when the bass hits. it runs fine when it not bridged. is it the amp or the way it is installed.
Username: Themax96se
Post Number: 42
What load are the speakers? Are you trying to run it bridge at 2ohms or less?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7331
if the sub is dual 4 ohm coils, your amp is seeing a 1 ohm load and going into thermal protection mode.
you picked the wrong sub/amp combination.
