Like
DVC 6 Ohm subs . . .
DVC6
Here's what I've got:
Onkyo HT Receiver (5.1)
Pioneer Stereo Receiver (50 Watts per channel, 6-16 ohm load per channel.)
Questions:
Can I connect
Onkyo Sub pre-out to a y-splitter to Pioneer inputs.
Pioneer outputs R to one voice coil and L to the other voice coil of a 10" car sub.
Will this work? Is it (100 watts) way too little power for a 10" sub?
Also, does anyone know of decent DVC 6-ohm (or 8 ohm, I'm not that picky) subs?
So far I've only found a couple . . .
JL 10W3-D6
JL 10W6-D6
Audiobahn ALUM10Q
MA Audio MA100D6
Do y'all know any others?
Username: Drumjunky
Boulder, Colorado
Post Number: 50
you can wire any sub that is DVC with each coil having a 4 ohm load to 8 ohms at the amp...that is more common than gettin' a 6 ohm load, unless you are doing a odd number of subs (usu. 3)
DVC6
Of course, If I am hooking up a dual 4 ohm sub in series to one side of my recevier, then I only have one side (and only 50 watts). Whereas, if I could hook up both left and right channels on my recevier to one sub (I don't know if I can do this), I could (theoretically) have 100 watts . . .
DVC6
I assume I posted in the wrong forum (or the question is so obscure no one knows) . . . Could anyone kindly direct me to the proper forum?
Facebook
Shop Related Deals
Directory
