Question about mmats amp
Username: Lexmaster
i have a mmats 700.2 amp and 2 mmats pro cast subs at 700rms each. If I run the subs in parallel, it comes down to 1400watts at 1 ohm. Is it possible to run this load on this amp even though it's a 2 ohm amp? I've heard that this amp is pretty good and should be able to handle the load but I need some professional advice from someone who knows about these amps and subs or has used them before. Thanks in advance for your help.
