Can Some-one tell me hot to fit 2 15's into a camaro
Username: 1994camaro
If some one can tell me or build me a box for 2 15 inch sub's to go under the rear bucket seat's of my 1994 camaro. I don't care if they are in the same box or two different boxes. But I do want them to fit in the back seat because I know there is no possible way they will fit in the hatch.
Username: Smeglor
Post Number: 8
You must be high on weed if you want 2 15s to go under the back seat.
Username: Glasswolf
Post Number: 1256
Adam, they really aren't going to fit there.. and they'd look awful if they did.
Is there a reason you're not using the drop section of the trunk in that car?
you can seal a baffle board over that section and use the entire air space of that drop section for the two fifteens in a sealed configuration.
That's just about the only way short of fiberglassing a box to fit that area.
You could go down to a pair of good 12" or 13" subs..
Username: Bdb_86
Post Number: 13
need some 12" speakers now, check out these barly used subs
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3078077156&category=48615&ssp agename=rvi:1:2
Username: Glasswolf
Post Number: 1268
yuck.
want a good pair of 12" subs?
look at some Adire Shivas
power the pair with a JBL BP1200.1
