Diamond Audio TDX or RE Triple X???
Flipino84
Would would I go with for 1 or 2 12" woofers? I have around 2000 watts rms. I want nasty kick as well sq. Thanx fellas.
Flipino84
Need Advice b4 buying.......Pleeeaaasssee!!!!!
what amp is it??
Flipino84
JBL Crown 2200.1
2 12" RE X.X.X.- they should sound good with 1000w a piece....
Flipino84
Thanx....I've been waiting for an answer b4 buying and your the only expert that has helped.
If I may, why do u pick the Triple X?
Username: Taylor17
Kopperl, Texas
Post Number: 33
Ya go with the x.x.x
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 154
I tihnk just about everyone in the forum would justy about pick the re X.X.X they can create extremly high spl levels while maintaing excellent sound quality
Username: Jonathan_f
GA USA
Post Number: 2947
You need to listen to both if possible. The TDX is not a slouch by any means, it is a great SQ subwoofer and puts out some very good SPL numbers, as does the RE X.X.X. The X.X.X. puts out more SPL, but SQ is subjective, and it depends on what you want more of. SQ of both is great, you'll just have to pick on what you prefer best.
Flipino84
Thanx guys! ;)
