Need Help picking out sub
Username: Jbgoalie4
Utica, New york USA
Post Number: 16
I currently own a dodge neon so there is not tons of trunk to use. I want a sub that sounds great for daily driving but I want to be able to turn it up if needed. I am looking for something top of the line or pretty close but dont want to spend too much money. I would like something I can crank up and blow the pants off my friends and their systems.
ANY suggestions?
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 137
How much money are you willing to spend. Also if you have an amp what kind and what are the specs of the amp?
Username: Jmloughrey
Farmington, CT
Post Number: 756
yea bass stole the words right outta my keyboard...we could easily name 100 subs but with no guidlines we might as well talk to a wall...
Username: Taylor17
Kopperl, Texas
Post Number: 24
You said that you want somthing close to top of the line, so I figure are going to spind the money!:-)
I would say a Jl 12w7 or maby even a 13w7.
Re x.x.x
Adire Brhama
and if you don't care about sq really, go with kicker l7's
Alpine type X
Alpine type R
and a hole lot more. lol
Username: Taylor17
Kopperl, Texas
Post Number: 25
I almost forgot, Eclipse T's.:-)
Miami, FLORIDA USA
Post Number: 143
yeh and if ou dont care about sq at all, go wit the juggernaut or the RE MT
you can not forget about audiobahn's superior SQ and cheap affordable price, Id have to say there the obvious choice.
nah im just fukkin wit ya
1 12" IDMAX- Has the best SQ of any sub IMO and gets loud when needed. They are Around $330 a piece. If thats too much, go with 1 12" Adire Shiva. ONly 125 dollars
Username: Jbgoalie4
Utica, New york USA
Post Number: 17
i dont have a box yet but it will be probably be slot ported and I Have about 800- 1000 max for sub and amp. I was thinking about the brahma. will it last long with about 900 watts at one ohm in a 1.25 slot ported box.
Username: Zepp
Post Number: 29
i would suggest the re sx, itll get plenty loud and you wont blow your entire wallet on it
Username: Taylor17
Kopperl, Texas
Post Number: 32
Ya the Brhama is a good choice!
Username: Jbgoalie4
Utica, New york USA
Post Number: 18
Is that the right wattage for the application
Username: Taylor17
Kopperl, Texas
Post Number: 37
900 watt's rms is perfect for that sub, as long as you have the box built for that sub!
Username: Jbgoalie4
Utica, New york USA
Post Number: 19
what type of box is that.
Miami, FLORIDA USA
Post Number: 156
ported
Username: Jbgoalie4
Utica, New york USA
Post Number: 20
what size ported box?
Farmington, CT
Post Number: 771
15cuft tunes to like 12hz....
geo
OK if i get a JL 12w7 what amp should go with it???
Username: James1115
Ct
Post Number: 176
jl 1000/1 why not stay with the same components if you can afford it. if not go kicker 1200.1 or jbl 1200.1 or mtx 1200 you get my point.
