Enclosure size, downward vs. horizontal firing
edster922
My sub:
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT10.1'&Ser=KPE&Cat=SUB
Sub boxes I'm looking at:
http://www.thezeb.com/caraudio/subzone_universal_sub_boxes.html
http://www.thezeb.com/caraudio/subzone_custom_truck_sub_boxes.html
http://www.crutchfield.com/S-oDZSCoWq8WW/cgi-bin/ProdView.asp?a=&s=0&cc=01&g=842 &id=features_and_specs&i=044QLTCS10
1. My extended cab Nissan can fit either a truck box or a hatch-box...is there any sound advantage with getting the bigger hatch-box?
2. What are the pros and cons of doing a downward-firing enclosure versus a normal horizontal one? Would a downward-firing sub require more or less power to produce the same amount of bass?
Thanks for your help!
