Subwoofer Box help
Username: Campthree2005
I just got a kappa perfect 12.1 for christmas with a box but my sub doesn't fit in the box i need a spacer to lift the magnet up off the back does anyone know if they make like a 12" spacer to go around the hole or something???
Username: Krijgy
Smithfield, Virginia United states
you never want to use a spacer when installing subwoofers, you are going to have to buy a new box. (typically) you have to buy a box that has about 3" of clearance from the magnet to the back of the box
Username: Redskin
LondonEngland
Post Number: 90
Why wouldn't you want to use a spacer on a sub?
Username: Addicted2bass
Miami, FLORIDA USA
Post Number: 144
I know some people that use spacers on there sub boxes. And they seem fine, as long as you properly do it. And make sure it doesnt flex or anything.
Username: Hdubb
Farmington, Nm Usa
Post Number: 271
if you dont use a spacer try sanding out a grove where the magnet would go. as long as you dont get carryed away it should work fine. but if the box is that small you might consider a bigger box
