Enough power??
strabismo
I have two DVC 4 ohm speakers. Dual 4 ohms rated at 750 rms. Will an amp the is 600 rms x1 at 4ohms bridged work with those two speakers and how much power will I get
Username: Taylor17
Kopperl, Texas
Post Number: 28
You will get 300 watt's to each sub, so you are under powering them. A good amp for you would be somthing like the mtx 1501 D
Username: Carguy
Post Number: 1014
It's always better to have a stronger amp than speakers. You see, most HUs will distort around 75-80% mark. So if your amp was stronger, you'd be hitting the max on your subs before the distortion kicked in with higher powered amps.
