Doing custom box ,question about neons?
Username: Drew2bm
Il
I am building a custom box for a 10" Alpine type E sub. I want to put 2 plexi glass windows in the box and i want to mount a neon accent tube inside. Has anyone else done this that can give me some advice? Does it cause problems like ruining the neon, (e.g. to where it wont light up)?
Username: Wojopro
Post Number: 112
Never done it before... Some are built pretty tough. I can almost say for certain that it will shorten its life. Just make sure where the power cable goes through the box is air tight!
Username: Smhuosrktays
Rochester, New York USA
Post Number: 38
just go and buy neon rope stuff, it wont affect the life of that stuff.
Username: Jmloughrey
Farmington, CT
Post Number: 755
use super thick plexiglass and dont even think about using a double layer of it, no matter how many screws you put in it, its make a slapping sound...i made that mistake, i had a box for 2 eclipse 10"s and put a plexi top on it...really wish i didnt waste that money on the sheet of 1/4 plexi....bad bad idea...
hogiekid
we put neons in a box that had seperate chambers for 2 12's and both 12's broke the neon in their chambers. it took about a week but then they stopped working. we were using the 12" neon like you buy from the auto supply. i would try the rope lights like suggested above.
for the windows we used 1/4" acrylic sheet. that seemed to work just fine.
