This system
would this system work
kicker 650.4 amp
4 kicker comps subs
1 kicker square L5
i would run the comps normally off the 4 channels and just bridge the L5 so its gettin like 700 watts at 2 ohms all the subs would be 12 inch wat would this system sound like with 4 round subs and 1 square.
Username: Jmloughrey
Farmington, CT
Post Number: 743
its get loud...as for SQ i couldnt tell ya, the CVR's are good subs, i have 2 L5's if you want em for cheap dual 2 ohms so you could run both at 2 ohms with 350watts to each, 700 would be more then the sub can handle...its only a 600rms sub
