Mono 1ohm stable amp reccomendation
Username: Mrdark
Post Number: 18
Any input guys?
Thanks!
Username: Drumjunky
Boulder, Colorado
Post Number: 30
what are you looking to pay? how many watts do you need? what is it going to be hooked to?
Username: Mrdark
Post Number: 19
About 300-400 dollars
Username: Carguy
Post Number: 998
PPI, Orion, RF, Audiobahn, Kicker make 1ohm stable amps.
Username: Hdubb
Farmington, Nm Usa
Post Number: 267
id would go with orion 1200d
Username: Fatryan
it seriously all depends on what your running. i got a kicker kx1200.1 for my L7's. and i love it. but what are you gonna push? if your around 1000w, then id say kicker, orion, jl, or ppi. if your talking 2000w+ then your limited to a few brands (unless you wanna bridge amps). for that you can go with an orion 2500D (sick amp), mmatts, or ma. i dont prefer those last 2 brands, but theyre about the best youll find for pushing that many watts. if your talking less then 1000w, then you gotts a million options.
Username: Bassfreak596
Post Number: 66
hifonics
