Box Size
Username: Eric77
Post Number: 68
I currently have my subs (2 diamond m6mkII 10d4's) running in a sealed enclosure, but I want to build a ported box just to see what the difference is. My biggest problem right now is that winisd recommends a 1.67 cu ft box (or is that 1.67 cu ft per woofer?) tuned to 32 hz where as diamond recommends 1.25 cuft per sub tuned to 38 hz. WHich if either of those should I go with? ALso, what would be the difference in those two boxes spl and sq wise? Thanks.
Username: Redskin
LondonEngland
Post Number: 88
If you've got winisd why not just model the two boxes and see what the difference is?
