Solobaric box
Username: Nysteelers
Post Number: 89
i have 2 12" L7's and i was just wondering if i got a box made for 2 12" round subs and just cut the openings to squares if this would be the same thing as a box made specifically for square subs?
Post Number: 90
somebody?
just go with the square enclosure
Username: Jmloughrey
Farmington, CT
Post Number: 761
well, whats the dimentions of it, thats all that really matters, will the internal dimentions work with the requirments of the L7's?
Post Number: 91
i have no specific one in mind, i was just wondering. If the dimensions are the same, would a box with circles cut out or squares cut out be the same?
Farmington, CT
Post Number: 764
a box is a box is a box is a box, its all about internal dimentions, there no trick to building a box for those subs, i've built a couple myself...just the cutout, as long as the internal dimentions work with the sub you're golden
Username: Fatryan
Post Number: 12
i got an old dual s12l7 box. you want it?
Post Number: 92
na its ok fehr, i was just wondering, i was almost sure that it wouldnt matter. and thanx jeff 4 the info
Username: Fatryan
Post Number: 13
ok, well if you ever decide you need a box, ill give it to you 4 free. its just taking up space in my garage now
Post Number: 93
alright thanx alot ill keep it in mind
