Can i use a sub
kuzz
my aiwa cdc-x504mp 's specs says it has a pair of preamp outputs but no sub preamp outputs. can i use a powered bazooka for this?
Username: Zepp
Post Number: 28
mine is the same way, i only have one preamp output, so the h/u sends everything to the amp, and i use the amps lpf to control what the sub plays
dont know too much about the bazookas though
to answer your question, however, yes, you can use the preamp regardless whether or not its a dedicated sub out
