Alpine SWX-1242D Type X 12", or kicker L7 12"
Jeff Roberts
if the Alpine SWX-1242D Type X 12", and kicker L7 12" were both powered correctly, does anyone know which would sound better/louder?
Username: Sublime420
Ca Us
Post Number: 16
the alpine will give u a better SPL. but the kicker might give you better SQ.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 155
ummm. I think that is backwards. The L7 is a SPL woofer.
yo yo
yea definitely.. the L7 is a pretty good sub, but definitely more SPL than a 12" type X... the type X is probably a good mix of both.. Depends on what you want.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 156
I have 2 15" l7's and they hit very hard, but the sq is just so so. They also require alot of power, but mine are in a sealed box. The 12's would sound alot better and still hit hard. I wish I would of got 4 12's instead. I think that the l7's would hit harded and the alpines would sound better. The l7's would sound good too.
taylor17
For all around I would go with the Alpine's, you will get way better sq, and still maintain spl.
Not to mintion not minny people have herd of Alpine type X subs.
Username: Wojopro
Post Number: 106
Type X would kick the L7's butt.... Hands down!!!! Plus not every guy in the world has them...
Username: Alpineblaster
I have 2 Type x 12's i they have great sq but the SPL could be better
