Like
Wire thickness???
wut gauge wires should i use to power a 2000 watt amp? and wut gauge speaker wire should i run to the woofers from the amp? theres two subs and im running them at 2 ohms any sugestions would be apreciated...
thank you
Username: Sublime420
Ca Us
Post Number: 21
14 or 16
well right now i have 4 gauge power wires and 10 gauge speaker wires i was thinking about going thicker with both
Username: Hdubb
Farmington, Nm Usa
Post Number: 210
go with 0/1 awg to the amp, 4 gauge for the ground and 10 to 12 to the speakers. it is hard getting 10 gauge to fit in the subs terminals and the boxes terminals
Username: Jmloughrey
Farmington, CT
Post Number: 725
woah, do not do what hunter said, do not run 0/1ga power and 4ga ground, you need to run the same size power and ground wire for it to actually be effective. As for speakers, 12ga would more then surfice anything bigger is just overkill....
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7137
here:
http://www.caraudiocentral.net/forums/showthread.php?t=551
Username: Hdubb
Farmington, Nm Usa
Post Number: 221
oops
Facebook
Shop Related Deals
Directory
