Mtx 342 and mtx 801D
Username: Erik123456
Arlington, Tx
Post Number: 315
will the 342 be a good match for my eclipse components (rms 125) it puts out 130x2 at 12.5 volts 2 ohm
and will the 801D be a good match for my 1 eclipse ti 12" (rms 750)
Arlington, Tx
Post Number: 316
anyone?
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 141
Sounds just right. Happy listening.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 142
Wait. I take that back. Your components are probably 4 ohm. That means that you will only get about 60w x 2. Goto MTX.com and see. I would try a bigger amp.
Arlington, Tx
Post Number: 317
how can you tell what ohm the components are - eclipse didnt have the specs in their brochure or website...
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 146
Standard impedance for components is 4 ohm. Not on website? Thats wierd.
