Underpower subs
Username: Langless28
Post Number: 66
does anybody think that the alpine mrd-m301 will underpower two 12's with specs of around 300w rms. the amp does 380w @ 14.4v. thanks. the subs are gonna be infinity's or polks. if they are uderpowered, is that amp too much power for a single 12" dvc with around the same specs?
Username: Sublime420
Ca Us
300rms each?
Post Number: 67
yeh
Username: Jmloughrey
Farmington, CT
Post Number: 719
if its 300x2 you should be fine, if the subs are 300rms a peice and the amp only puts out 300x1 then you may need a bigger amp or just a single sub...
