Amp qustions plus car laptop
Hello car audio enthusiasts.
I have an older car that has been broken into many times. I recently made three sealed boxes. Each houses a jbl 12 sub, Kappa series. They are 350 watts,
My first questions is Amp, what should I look for to power the three subs, should I look for a 1000 watt amp, also how to wire parrellel or serires. I read something that said for each additional speaker I pick up 2 ohms?
My second question, I want to only use my laptop to power all the sound in my car, meaning is there a way I can re-wire all the speakers from the factory radio back to the amp then us a mic cord to send my music to the amp thus powering all the speakers.
I am planning to get the newer phillips mp3 player to use instead of a laptop in the car
kristina
u have re wire the factory amp which is a real pain in the A$$. u probably have to by pass some wires for your labtop. id go with more than 1000 watts for your amp.i have 3 12"s and a 1200 watt amp. well i unhooked the middle sub cause there wasnt enough power, it didnt sound to hot.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 122
Get an 1/8" stereo to dual rca adaptor. Radio Shack should have 'em. Then run regular car rca wires to your amp to keep noise out.
