Alternator in 99 grand cherokee
Username: Scab12886
Post Number: 35
i have a 99 jeep grand cherokee and i was wondering if anyone knew what size alternator is in my car. i was thinking sometime in the future i would have probably a 300/2 amp and a 1000/1 sub amp. is my alt. big enough for this? or would i need a new one? or could a cap. solve any problems i may run in to? thanks!
Username: Djeter108
IN USA
Post Number: 103
https://www.ecoustics.com/electronics/forum/car-audio/114710.html
cant remember which thread, but jeeps apparently have week alternators. go to the wickedcases site, too. cap does not replace an altenator
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 6968
wranglers do.
depends on the engine in the JGC.
If it's a Laredo with the 4L i6, you have a 90A denso alternator.
If this is a fully loaded Limited, with a 4.7: V8 it'd be bigger.
in any event for over 1300 watts of power you're going to want a bigger alternator.
www.mralternator.com has them for jeeps.
Username: Scab12886
Post Number: 36
thanks for the help glass. i do have the limited with the V8. with this said i still looked at the site you suggested in your last post, and the alts. for grand cherokees seem to only go up to 1997 on that site. am i looking in the wrong place for them? any other input would be great, thanks!
Username: Glasswolf
Post Number: 7021
I guess they only list for the ZJ bodies.
yours is a WJ body. contact the site directly via email and ask.
if you have no luck there, try www.4alterstart.com
