Clifford cyber 75 install guide
i need an installers guide to a clifford cyber75 so i can get the starter kill to work... i took the ignition wire and split it thru the brain of the alarm but i can still start my vehicle when the alarm is on....dgregson69@hotmail.com
Username: Jeremyc
Kunsan AfbSouth Korea
Post Number: 316
Hay you need to tie the wire in before your coil. There is a 12v + that suplies your voltage to your coil before it gets split and sent to the plugs.
