8 inch
Need some opinions on some 8 inch subs. I chose 8 inch cause im trying to work behind my seat of my truck and i really dont want to pull the bench all the way forward. So im looking for some 8 inch subs that will pound. I have 500 dollars to get subs and im sure that willl be enoug.
Username: Kklagge
Post Number: 28
Used to have some 8" Kicker CVR's and they sounded pretty good for 8" subs.
anonymous1
jl w7 8"-$299
pricey but it must thump, ive never heard them.
anonymous1
jl w7 8"-$299
those 8w7 are just a it to deep for my use..
Username: Cheapskate
Post Number: 73
if you need 8" subs that are shallow, earthquake just released 8,10 and 12" low profile woofers. they are up in the $200+ JL audio price range, but if mounting depth is an issue, they might be what you're looking for.
i read one favorable review for a different earthquake woofer somewhare, so i'd imagine their low profile woofers aren't shabby.
hope this helps.
8" woofers are my favorites. :-)
i just had to visit this thread.
thump on!
Username: Xxkmfdmxx
Saint Petersburg, FL USA
Post Number: 144
The only 8" sub I used so far are the MTX T688, Their pretty good for how cheap you can get them.(20-40 on ebay)
Any other opinions?
Username: R1rider
Hope Mills, NC US
Post Number: 12
I'm no expert but I have the same issue you have and I have been looking for some sub's. Here are a couple
Kicker S8L7
ID8's V.2,V.3
CM3 08D4 by Diamond audio
They are under 5" mounting depth.
There is a bunch more you just have to look hope this helped
Victor
