Bronze Member Username: Pdivvy5New Port Richey, FL United States Post Number: 84 Registered: May-04 | I was wondering if this amp http://www.cardomain.com/item/PHOR801 is good to power my 2 JL 12 W0's. It looks good, but i was just wondering if you guys knew anything else about it. I looked it up on ebay, and there is one for like $220, which is in my price range. Thanks guys |
Gold Member Username: GlasswolfNorthWest, Michigan USA Post Number: 6963 Registered: Dec-03 | too much power. look for an amp that's 300 watts RMS x 1 @ 2 ohms, not 4 ohms if you're driving two 4 ohm 12W0 subs. they only take about 125wRMS each. |
Bronze Member Username: Pdivvy5New Port Richey, FL United States Post Number: 85 Registered: May-04 | But my subs are 8 ohm subs...so what should i do? |
Bronze Member Username: James1115Ct Post Number: 98 Registered: Dec-04 | ok then that would be fine. Just for the sake of being easy next time you post about a sub or a sub ? just tell the VC configuration off the bat! But no biggie. That amp will do damage to those subs if turned to high so be carefull. James |
