2 channel amp to sub???
Username: Killer44
Niagara Falls, Ontario Canada
Post Number: 10
How should i connect a 2 channel amp to my mmats 12 inch 250 rms sub...amp is a 300watt max,,,170rms power acoustik gothic series...
Username: James1115
Ct
Post Number: 109
is that power rating of the amp at 4ohms? also what impedence are the voice coil/coils of the sub?
Username: Killer44
Post Number: 14
@ 4 ohms the amp is 70x2....the one i gave u is the mono rms
thats all the stuff on the amp
250 WRMS power rating
2" four layer dual voice coil
Double stacked 60 ounce magnet
High excursion suspension with flat spider
Poly cone and foam surround with polymer sealant
SPL 1W/1M,12" 89dB,15" 91dB
Dual 4 Ohm Voice Coils
Username: James1115
Ct
Post Number: 112
ok what you need to find out is if that amp is stable at 2ohms mono not stereo. Cause 2ohms mono = 1ohm stereo.
Username: Killer44
Post Number: 17
i found all this on the website...(www.poweractoustik.com)
Super Cool Blue LED
Chrome Top Plate Panel
Full Mosfet Power Supply
PWM Circuitry
Full Selectable Crossover Hi/Full/Low
Three Way Protection Circuit
Tri-Mode Capable
Variable Low Pass 40Hz-120Hz
Variable Hi Pass 150Hz-1.5Khz
18dB Bass Boost @ 40Hz.
Frequency Response: 10Hz to 30Khz
S/N Ratio:97 db
THD: 0.02%
2ohm Stable Stereo
System Distress Indicator
High/Low Level inputs With Floating Ground
4 Gauge Power/Ground Connection
Gold plated RCA Connectors
Line output
*and then it says MONO RMS 170....
Username: James1115
Ct
Post Number: 113
ok 2ohms stereo so it is not stable at 2ohms mono I didnt think it would be. You can run it two different ways. 1)run it stereo one channel to each voice coil and you will get 2ohms stereo. or 2) run it series/parellel and yield a 8ohm load which wont give you enough power. If you havnt bought this amp yet I would look more for like a 300 watt RMS mono amp. Check into Alpine,JBL,Kicker,ect..... but if you already bought this amp then do what you can with it or maybe try to sell it. thats just my opinion. I dont think power acoustic is very good anyways.
but again thats my opinion!
James
Username: James1115
Ct
Post Number: 118
no you shluld be fine. well go with whatever works for you man. In the future just start one thread for each ? that you have you will get a better response.
James
